Customization Options for Garmin Instinct 2X Series Watch Face
The Instinct® 2X series watches offer ten pre-loaded unique watch faces, with a color inverted option of each. Additionally, each watch face has the ability to customize what data or symbols to display. The selected watch face may change what can be customized, what options are available or how the data appears. Depending on the watch face, you will have two to seven data customization options.
Example:
Instinct 2X Solar watch face
Customizing the Watch Face
  1. From the watch face, hold UP/MENU.
  2. Select Watch Face.
  3. Press UP/MENU or DOWN/ABC to preview the watch face options.
  4. Press GPS to select the desired watch face:
    • To activate the watch face, select Apply.
    • To customize the data that appears on the watch face, select Customize.
      1. Press UP or DOWN to preview the options.
      2. Press GPS to apply.
      3. Complete for all available data fields until you see a check in the dial screen.
The Garmin Instinct 2X series offers a unique display with a dial screen in the top right corner to isolate different data options. For more information on the Dial Screen options, select Dial Screen below.
Dial Screen
The following options are available on most of the watch faces. Many of these options can be viewed on the other data fields outside of the dial screen.
Moon, battery, phone, and clock symbols.
Status Icons
Displays current battery life, if the watch is set to Do Not Disturb, if an alarm is set, and if it is paired with a phone.
Rectangle battery symbol with small lines indicating battery amount.Battery Life
Displays the remaining battery life.
Day of the week abbreviation above numbers.Weekday and Day
Displays the current calendar date and day of the week.
Month abbreviation above numbers.Day and Month
Displays the current calendar date and month.
Heart symbol above numbers.Heart Rate
Displays the reading taken from the optical heart rate sensor (OHR).
OHR sensor must be on to get a reading.
Two footprints above numbers.Steps
Displays daily step count.
Triangles above numbers.
Elevation
Displays your current elevation.
Horizontal arrow above numbers.Barometer Trending Line and the Barometer Reading
Will display the current barometer pressure in millibars.
The barometer trend line considers the last 6 hours, broken into two 3 hour segments. If there is a 2.3 millibar change over the 3-hour segment, the line will curve up or down depending on the direction of change.
Setting sun symbol on top of numbers.Sunset/Sunrise
Displays Sunset/Sunrise time.
Square text bubble over numbers.Notifications
Displays the number of notifications.
Notifications number won't be cleared until they are cleared from the phone.
Square calendar symbol over two small dashes.Calendar Notifications
Display the number of calendar notifications for the day.
Word NOW over number with degree symbol.
Weather
Displays the weather information received from the Garmin Connect App.
Flame symbol over numbers.Calories Burned
Displays total calories burned for the day.
Arrow and line representing stairs above a number.Floors Climbed
Displays floors climbed for that day.
Circle and lines and numbers.Intensity Minutes
Displays the number of intensity minutes generated for the week.
Circle with lines inside above numbers and percentage symbol.Pulse Ox
Displays the last pulse oximeter reading.
Person running over numbers.Weekly Run Total
Displays distance of all running activities for the week, except Trail Run.
Person cycling over numbersWeekly Cycling Total
Displays distance of all cycling activities for the week.
Letters UTC above numbers.Universal Time Coordinated
Displays Universal Time Coordinated (UTC).
UTC is the successor to Greenwich Mean Time (GMT).
Sun symbol with rectangles around the edge.
Solar Intensity1
Displays current solar intensity and fills in as solar intensity increases.
Sun symbol with white and black background.
Sun Position
Displays the current position of the sun.
Moon with light and dark
Moon Phase
Displays the current phase of the moon.
There are three watch faces that offer a graph data field. The small graph watch face offers all the Dial screen options listed above. The Large Graph watch face offers only four1 of the Dial screen options. Information on the graphs and what options are available can be found by selecting an option below.
Small Graph Watch Face
The small graph watch face offers a graph displayed in the top left corner. There are two watch face options that offer the small graph. Other data field options that can be customized are located below the current time.
Line graph of barometer data with barometric pressure.
Barometer Graph
Displays current barometric pressure and graph showing the change of barometric readings over the last four hours
Line graph of elevation data with current elevation number.
Elevation Graph
Displays current elevation and graph showing the change of elevation readings over the last four hours
Line graph of heart rate data and current heart rate number.
Heart Rate Graph
Displays current heart rate in beats per minute and graph showing heart rate readings over the last four hours
Line graph of solar charging data with battery estimate.
Solar Graph1
Displays graph of changes in solar intensity over the last six hours
Line graph of daily step data with footprint step symbol and number of steps.
Steps Graph
Displays total step count for the day and a bar graph showing steps generated over the course of the day by hour
Large Graph Watch Face
The large graph watch face offers graphs that display depending on the dial screen option that is selected. This watch face offers a limited amount of dial screen options. There are two other data field options that can be customized, located above the current time and below the graph.
Line graph of barometric data with day, date and time.
Altimeter Graph
Displays current barometric reading, barometric trending line, and a graph showing the change of barometric readings over the last six hours.
Displays the current barometer pressure in millibars.
The barometer trend line considers the last 6 hours, broken into two 3 hour segments. If there is a 2.3 millibar change over the 3-hour segment, the line will curve up or down depending on the direction of the change.
Line graph of elevation data with day, date, and time.
Elevation Graph
Displays the current elevation based on unit settings and a graph that displays change.
Line graph of heart rate data with day, date, and time.
Heart Rate Graph
Displays the current heart rate and a graph showing the change of heart rate over the last four hours.
Line graph with solar intensity data and day, date, and time.
Solar Graph1
Displays graph of changes in solar intensity over the last six hours.
For more information on the Garmin Instinct 2X series watches, refer to your owner's manual.
1Solar data only available on watches with solar charging.
