Garmin Watches That Have the Dog Tracking Glance or Widget
Many Garmin® watches offer a Dog Tracking Glance (previously known as a widget) that allows you to receive information from a dog tracking handheld.
For more information on using the DogTrack glance, or pairing a compatible handheld dog tracking device, select a topic from the list below:
Topics
Dog Track Compatible Devices
Compatible Watches
  • D2™ Bravo
  • D2™ Charlie
  • D2™ Delta | D2™ Delta PX | D2™ Delta S
  • D2™ Mach 1 | D2™ Mach 1 Pro1
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition1
  • Descent™ G2
  • Descent™ Mk1
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S1
  • Descent™ Mk3 | Descent™ Mk3i1
  • Enduro™1
  • Enduro™ 21
  • Enduro™ 31
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition1
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition1
  • fēnix® 3 | fēnix® 3 HR | fēnix® 3 Sapphire
  • fēnix® 5S | fēnix® 5 | fēnix® 5X
  • fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition1
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition1
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition1
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition1
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition1
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition1
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition1
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition1
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition1
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition1
  • fēnix® 8 Pro - AMOLED | fēnix® 8 Pro - MicroLED1
  • fēnix® Chronos
  • fēnix® E1
  • Forerunner® 935
  • Forerunner® 965
  • Forerunner® 970
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition1
  • Instinct® E1
  • Instinct® - Standard Edition | Instinct® - Tactical Edition | Instinct® - Esports Edition
  • Instinct® Solar - Standard Edition | Instinct® Solar - Camo Edition | Instinct® Solar - Surf Edition | Instinct® Solar - Tactical Edition
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition1
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition1
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition1
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition1
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition1
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar1
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar1
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer1
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)1
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition1
  • quatix® 5 | quatix® 5 Sapphire
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro1
  • tactix® Bravo
  • tactix® Charlie
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics1
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition1
  • tactix® 8 - AMOLED | tactix® 8 - Solar1
1 The Dog Tracking Glance will automatically appear in the glance loop when paired with a dog tracking device.
Dog Tracking Handhelds That Transmit to the Dog Tracking Glance
  • Alpha® 10
  • Alpha® 100
  • Alpha® 200 & Alpha® 200i
  • Alpha® 300 & Alpha® 300i
  • Astro® 320
  • Astro® 430
  • Astro® 900
  • PRO 550 Plus
Preparing Your Dog Tracking Handheld
Before you can view the dog list on a watch, the handheld needs to be set up. For your handheld to broadcast dog data to your compatible watch, the handheld and watch must be within 15 feet of each other. Select your dog tracking handheld model below for steps.
NOTE: For best results, ensure any other broadcasting handhelds are powered off.
Alpha® 100
  1. Select Set Up.
  2. Select Dogs.
  3. Select Broadcast Dog Data.
  4. Select Enable.
Alpha® 200 | Alpha® 200i | Alpha® 200 Plus | Alpha® 300 | Alpha® 300i
  1. Select Set Up.
  2. Select System.
  3. Toggle on Broadcast Dog Data.
Alpha® 10
  1. Select Set Up.
  2. Select Remote View.
  3. Select Status.
Pro 550 Plus
The Pro 550 Plus uses ANT+ to share dog locations to your compatible outdoor watch and broadcast dog data by default. No other steps are required on the handheld. To start, ensure your handheld is up to date on the latest software.
Astro® 320 | Astro® 430 | Astro® 900
  1. Select Set Up.
  2. Select Dogs.
  4. Select Enable.
Back to Topics
Setting Up the Dog Tracking Glance
When a dog tracking device has been paired to the watch, the Dog Tracking glance automatically appears in the widget or glance loop. The widget or glance cannot be added before a dog tracking device is paired. Follow the steps below to add your dog tracking device to your watch:
  1. Access the Settings menu of your watch.
  2. Select Sensors & Accessories or Connectivity > Sensors & Accessories.
  3. Select Add New.
  4. Select DogTrack.
  5. Select the dog tracking handheld and wait for the pairing to complete.
  6. Return to the watch face.
  7. Scroll up or down from the watch face to locate the DogTrack widget or glance.
If the Glance or Widget does not automatically appear after pairing your handheld, you may need to add the Glance or Widget. Refer to your owner's manual and search for "Customizing the Glances List" or "Customizing the Widget Loop" for instructions.
NOTE: To view a dog on the widget, the dog collar needs to be turned on and actively tracking.
Back to Topics
Views and Alerts
Your watch offers different views to see your dog's status and information, along with alerts for your dog's status and movement.
Mode Views
To change the Mode View, press the START/STOP button on your watch. When you are on a current Mode View, you will only see the other Mode View options. Available Mode View options may vary based on your watch model.
  • Alpha View: Shows one dog and related information per page. To view the next dog, press the Down button.
  • Pro View: Shows a list of the dogs and information on the screen, including distance to and heading to the dogs.
  • Compass View: Shows one dog and related information with a compass view. To view the next dog, press the Down button.
  • Map View: Shows a map of your area with dog locations and status, as well as your truck and your location.
Indicators
You are able to change the way the indicator looks on the watch screen when viewing the dogs in Pro View.
  • Status: Shows the dog status as running, sitting, treeing, or pointing.
  • Direction: Shows a directional arrow in the dog's track color.
Dog Alerts
You can customize the alerts you receive of your dog's status and movement. When enabled, Dog Alerts displays a message notification along with a vibration to alert you of your dog's movement status, and changes to pointing or treeing. Alert customizations may include the following:
  • Vibrate Only
  • Tone Only
  • Message Only
  • Vibrate  and Tone
  • Alerts Off
Back to Topics
Troubleshooting the Dog Tracking Glance
If your watch is unable to find the signal from your dog tracking handheld, first ensure that the handheld is broadcasting the signal. If the handheld is broadcasting, reset the pairing on the watch by turning off the DogTrack Status and then turn it back on again.
  3. Select DogTrack.
  4. Select Status to toggle off.
  5. Select Status again to toggle back on.
Removing and Pairing the Dog Tracking Handheld
If the above does not resolve the issue, remove the handheld pairing on the watch, and re-pair using the following steps.
  3. Select DogTrack.
  4. Select Remove.
  5. Select Add New.
  6. Select Dog Track.
  7. Select the dog tracking handheld and wait for the pairing to complete.
Still Unable to See the Dog Tracking Glance
If the above troubleshooting steps do not resolve your experience ensure your software is up to date on your watch or your Dog Tracking handheld:
Compatible watch:
Dog Tracking Handheld:
Back to Topics
What is Easyhunt?
EasyHunt is a feature that is only available for those in the Nordics. This is not available for use in North America.
Back to Topics
Related
