Pairing the Alpha 200/200i With the Alpha Mobile App
Using an Alpha® 200 or Alpha® 200i dog tracking handheld and the Alpha® Mobile app allows you to view your live hunting activity and dog tracking information right on a smartphone. The following guide will show how to get started with pairing the Alpha 200 or Alpha 200i handheld with the Alpha Mobile app.
NOTE: The Alpha 200 and Alpha 200i handhelds do not pair with the Garmin Connect™ app.
Getting Started: Updating Software and Pairing to the Alpha Mobile App
Before Beginning
- Update the software on the Alpha 200/200i handheld to the latest version
- Install the latest Alpha Mobile app on a smartphone with either Google Play for Android or the App Store for iOS
- After downloading the app, log in with the Garmin account credentials or create an account by selecting Create One and follow the prompts
- Ensure Bluetooth is enabled in the smartphone settings
Pairing Procedure
Enabling Bluetooth on the Alpha® Handheld
- Select Setup.
- Select Bluetooth.
- Select Continue.
- Open and sign in to the Alpha Mobile app on the smartphone:
- Select Pair Device on the first screen prompt.
- NOTE: If you are not prompted to pair, touch
Devices at the bottom of the screen, then touch Pair Device or +.
- Select your model of Alpha handheld
- The app will present a list of potential nearby Bluetooth devices that are transmitting or already in the Bluetooth list.
- Select your Alpha model
- After several moments the Alpha and the smartphone will both show a passkey number to verify the correct device being paired.
- A Bluetooth Pairing Request notification will pop over the app, touch Okay to confirm the pairing request.
- On the smartphone, touch Continue to finish the pairing process.
- On the Alpha handheld, touch Done.
Overview of Features on the Alpha Mobile App
- Review recorded tracks and/or activities
- Download maps
New Features Enabled When Paired a Dog Tracking Device
- Shows Dog Status icon – treeing, pointing, sitting
- Shows Dog Name
- Dog Track Color matches the colors on handheld – red, blue, black
- Adjust how long the dog tracks show on the map
- Dog movement Speed Indicator
- Any part of the track that shows a segment of the dog moving faster than a certain speed will show up as a thicker line on the map
- Useful to know if the dog is chasing something at that part of the hunt
- Choose either faster than 5 mph, 10 mph, 15 mph, or Off:
- Touch Map tab.
- Touch Map Settings top left of screen (layer icon).
- Touch Line Display Settings.
- Touch Speed Indicator.
- Select the desired speed threshold.
