Instructions to Sync Deezer Content to a fēnix E Watch
This article will provide instructions to set up and sync Deezer music and podcasts to your fēnix® E watch.
Requirements
The following are requirements to use the Deezer app with your watch:
I Meet the Requirements. What Do I Do Next?
The three steps listed below need to be completed when first setting up the Deezer app with your watch. Once complete, you will only need to follow the third step when you want to load additional content to your watch. Select each section to expand and view instructions on completing each step:
Step 1: Download and Install the Deezer Connect IQ™ App
  1. Select the following link to download the app - Connect IQ app for Deezer.
  2. Select Download.
  3. If prompted, sign in to your Garmin account.
  4. Select your watch to download the app.
  5. Acknowledge any app permission requests.
  6. Sync your watch:
    • To sync via Bluetooth: Be in range of your paired smartphone, and open the Garmin Connect app. Select blue sync arrows  on the My Day page to sync.
    • To sync via Wi-Fi: Be in range of your previously set up Wi-Fi network, and hold the UP/MENU (middle left) button on the watch. Scroll down and select Watch Settings > Connectivity > Wi-Fi > Wi-Fi Sync and wait while the watch connects to Wi-Fi and syncs.
    • To sync using Garmin Express™ software:  Connect the watch using supplied power/data cable to the computer. Open Garmin Express program. A sync will start automatically once your watch is detected.
The Deezer app will now be installed to your watch.
Step 2: Set up the Deezer Connect IQ App
Your watch must be connected to your Wi-Fi network and your paired smartphone.
  1. On the watch, press and hold UP/MENU.
  2. Select Watch Settings.
  3. Select Music.
  4. Select Music Providers.
  5. Select Deezer.
  6. The watch will display the message, Open Garmin Connect on Phone.
  7. Select Next.
  8. Your smartphone will ask you to sign in.
    Connect IQ Deezer Sign In
  9. Acknowledge the message on the phone which will take you to a Deezer sign in. Depending on whether you have an account, the login process will be as follows:
    • Existing Deezer users: Enter your login details and select login. From here, skip to Step 3.
    • New to Deezer: Select Register here, and follow the steps to create your account.
  10. If prompted, enter credit card details to complete the process.
Step 3: Selecting and Syncing Content to the Watch
From your Deezer account, create playlists or you can download existing playlists. For more information, see Make playlists or edit an existing Deezer playlist on Deezer Support.
  1. On the watch, press and hold Down (the music shortcut key).
  2. Press and hold Menu to access settings.
  3. Select Music Providers.
  4. Select Deezer.
  5. Select My Playlists.
  6. Select a playlist.
  7. Select Done.
  8. Press the BACK button and select Yes to Start music sync now?
At this point, the watch will attempt to connect to your Wi-Fi network. We recommend plugging the watch into a charger near the Wi-Fi router for the best results.
Related
