Please be informed that, in conjunction with the public holiday in Malaysia for Prophet Muhammad's Birthday on Friday, September 5, 2025, our call center services will be unavailable. Regular services will resume on Monday, September 8, 2025. We apologize for any inconvenience caused and appreciate your kind understanding.
Truck Types Supported by the Garmin eLog
The Garmin eLog™ Compliant ELD will function with and transfer information through most trucks which have an On-Board Diagnostic (OBD) port with a 9-pin J1939 configuration. The Garmin eLog includes a 6-pin J1708 adapter cable for trucks with a 6-pin configuration. Garmin eLog ELD supports both 250kbps and 500kbps baud rates, depending on which baud rate your truck is equipped with.
More Compatibility Information:
  • The Garmin eLog ELD is not compatible with vehicles using the OBD-II protocol (SAE J1979).
  • Volvo Trucks with a Volvo engine and 16-pin J1962 configuration will require a 16-pin to 9-pin adapter cable.
    • This cable is not sold by Garmin but can be found online.
    • Only this cable has been tested to work properly with the Garmin eLog.
    • 16-pin J1962 configurations requiring this adapter are only tested to be supported with Volvo engines.
    • Volvo Trucks using a standard 9 pin or J1939 configuration are compatible and do not require any additional adapter cables.
  • Trucks with an RP1226 diagnostic port will require an RP1226 to J1939 Type 2 adapter cable.
  • Hino trucks are unsupported at this time.
  • 2016 and Newer PACCAR/Peterbilt/Kenworth Trucks will require a 9-pin to Y cable adapter.
  • All other port configurations and truck types have not been confirmed as compatible and may not be supported by the Garmin eLog ELD.
    • Incompatible port configurations and truck types may result in malfunctions, missing data, and errors in the data recorded by the Garmin eLog ELD.
Related
