Correctly Spelling and Formatting Destinations
The destination may not have been spelled correctly or entered in the proper format if your device displays the error "No matches found" or "Cannot Find Search Results" when searching for a destination - especially an address.
Searching for a street using abbreviations (N, E, S, W, ST, etc.) is generally acceptable. However, since addresses are sometimes abbreviated differently, it is often easier to leave the abbreviation out completely.
For example: when searching for "1200 E 151st St", it is best to enter "1200 151". This will yield a list of results where the correct address can usually be selected from a list. Try removing any abbreviations from your desired address, and only enter the house number and street name.
A Detailed Video Walkthrough Can be Found Below:
Try the Following in Order if the Errors "No Matches Found" or "Cannot Find Search Results" Continue to Appear when Searching for a Destination
Go to the Support Center and enter the product name or the serial number of your device. Once your device is selected, in the Search for a solution... field enter any of the following FAQs:
- Verify the Maps on an Automotive Device are Enabled.
- Searching Near a Different Location.
- Verifying Maps Installed on an Automotive Device.
