Save Part of a Track Log as a Route
Your device has the ability to convert previously traveled trip data into a route for future use.
To Save a Segment of Your Trip/Track Log as a Route:
- Touch Apps or
- Touch Where I've Been
- Touch the desired track
- Touch the wrench icon
- Touch Save As Route
- Select the preferred routing preference, either Start to Finish or Finish to Start
- Input a name for the new route
- Touch Done
Once calculated, you can go to Trip Planner and touch Map to see the route the unit created. You may also edit the route to change the points on it or touch Go! to start the route you created from the trip log.
To Convert a Saved Track to a Route:
- Touch
- Touch Tracks
- Select the desired track
- Touch Convert to Route
- Touch Done
