T5 mini / TT15 mini LED Flashing Red on Charge
The status LED on my T 5 mini or TT™ 15 mini collar flashes or blinking red continuously when on charge.
- Inspect the charging clip to ensure there is a clean and complete connection with the collar
- If necessary ensure the collar has had adequate time to warm to room temperature before charging
- Ensure the collar was charged at room temperature
My T5 mini / TT15 mini collar failed under warranty.
If you agree to the following and your T5 mini or TT15 mini collar failed under warranty, complete the process below to obtain a replacement.
- We are shipping the replacement to an address within the United States only
- You will need the serial number located on your device How to Locate the Serial Number
- You will need to provide your email address which is where we will send an email to complete the exchange setup process
You can get started on the warranty replacement process here: T5 mini / TT15 mini Flashing Red on Charge Replacement Program
