Why a zumo 590/595 Device Isn't Charging
Garmin's zumo models will only charge when certain conditions are met.
  • When connected to a motorcycle mount, the zumo will only charge if it is powered on. If the zumo is in sleep/standby mode (if available) or powered off, then it will not charge.
  • When a zumo, on its automotive mount, is connected to the proper vehicle power cable the zumo will charge regardless of whether it is on, off, or in sleep/standby mode (for those models that have this feature).
  • The zumo should charge at all times when connected to a computer via a USB cable as long as the USB cable is plugged directly into the device. Plugging the USB cable into the mount will not charge the zumo.
Temperature and exposure to sunlight can also prevent battery charging. If the zumo gets too warm or too cold, the battery will no longer charge as a means of preventing overheating.
See a the Video Below on Accessing the Battery Compartment in Order to Connect to the Computer.
