Important Notice: Beware of Fake Garmin Ads!
Garmin Philippines has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
(2023) Service Bulletin 23037 Rev B: GPS 175/GNX™ 375/GNC® 355 Main Software Version 3.21 and GNX 375 Transponder Board Software Version 2.80
PRODUCTS AFFECTED:
GPS 175, GNC 355, and GNX 375 products listed below with Main Software Version 3.20 and earlier are affected:
Table 1. Products Affected
ModelAppliance P/N
GPS 175011-04377-00
GNX 375011-04378-00
GNC 355011-04956-00
GNC 355A011-04956-30
CERTIFICATION AUTHORIZATION:
TSO Authorization
TSO Authorization does not provide installation airworthiness approval. Separate installation airworthiness approval is required for type-certified aircraft. Notification of revision to any Garmin STC(s) will be provided under a separate service bulletin.
COMPLIANCE:
Recommended: Compliance with Service Bulletin 23037 is recommended for the models listed in Table 1.
PURPOSE:
GPS 175/GNX 375/GNC 355 Main Software Version 3.21 contains the following changes from Main Software Version 3.20:
  • Corrected an issue where some 1090ES ADS-B and ADS-R surface targets may erroneously appear as directional on the GNX 375
  • Improved flight plan importing from a PED
  • Added option to set the CDI Scale on the GNC 355
GPS 175/GNX 375/GNC 355 Main Software Version 3.21 contains the following changes from Main Software Version 3.12:
  • Added support to use Fuel data from G500(H)/G600/G700 TXi and GI 275 EIS units on the Fuel Planning Page
  • Added support for the following RS-232 Fuel formats for fuel data to display on the Fuel Planning Page:
    • FADC Format 1
    • Fuel Format 1
    • Fuel Format 2
NOTE
This feature requires settings to be entered in configuration mode: Setup > Interfaces > RS-232.
  • Flight plan waypoints that are used for transitions are now displayed in gray text on the flight plan page
  • Route waypoint types have been expanded to include fly-over waypoints
  • User waypoint were expanded to support user airports
  • Added Crossfill support for sharing flight plan information between two Garmin navigators: GPS 175, GNC 355, GNX 375, GTN (v6.72), and GTN Xi (v20.30)
NOTE
This feature requires settings to be entered in configuration mode: Setup > Interfaces > Cross-Side Navigator.
  • Added support GPS 175 and GNC 355 to receive ADS-B traffic and weather data from a GNX 375
NOTE
This feature requires settings to be entered in configuration mode: Setup > Interfaces > ADS-B SRC.
  • ON GNX 375 OAT user data fields now display when OAT temp probe is installed
  • Fixed an issue where users were receiving “ABORT APPROACH” messages when flying LNAV+V approaches
  • Fixed an issue with Label 100 in GAMA output formats to allow GDU 620 to change the CDI from GPS to VOR
  • Fixed an issue with tuning the GNC 355 COM radio from the G3XT. The MapMx Format 2 interface now sends the correct COM channel spacing value
  • Expanded flight plan feature to allow removing a hold at the final approach fix
  • Improved the accuracy of the internal AHRS processing for calculating attitude (pitch and roll) provided to a portable electronic device
WARRANTY INFORMATION:
For GPS 175 and GNC 355 products, this modification is reimbursable under the original Garmin factory warranty.
For GNX 375 products, this modification is warranty reimbursable with a deadline of October 31, 2023.
Related
