Xero S1 Wrong Language Selected
If the Xero® S1 trapshooting trainer is displaying the wrong language, you can perform a Factory Reset and select the language again.
Note: A Factory Reset will delete all profile and scoring data on the device, and set all menus back to default.
- Power the Xero S1 trainer OFF
- Press and Hold Power button in
- The status light on the lower right of the display will flash green for one second, then flash yellow
- Continue to hold Power, but then tap the middle of touchscreen 5 times
- Release Power button
- Select Language and follow the reset of the setup options as prompted.
