Garmin Philippines has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Garmin Marine Handheld Interface and SD Memory Card Requirements
Newer Garmin® marine handhelds will mount to the computer so that the internal memory can be easily accessed (typically known as a mass storage interface). Many older and newer models include an expandable memory slot. The internal memory on an installed micro/SD card stores the following:
Additional mapping
BirdsEye imagery
Photos (on devices with a camera)
GPX files, including geocaches, waypoints, routes, and tracks
As long as the device has the latest software version, it can use the maximum card size from the tables below. To verify that the handheld is running the newest version of the software, follow the steps in Installing the Latest Software Updates for Marine Handhelds.
Essential Items Regarding the Information in the Table Below
Interface Options include:
Mass Storage: Can access the internal memory
MTP: By default, can access internal memory on Windows but not on Mac
Garmin Mode: Cannot access the internal memory
When using a card with a larger capacity, the device may draw maps more slowly if there are too many files or large files on the card
There may be other file limitations that apply to the device. For more information, refer to the section below:
Data Limitations on Marine Handhelds
Click here for links that detail data limitations specific to your device
Select the device series below to view a table of interface options and card requirements.
NOTE: If the device is not listed here, it may be one of our Garmin legacy models. Legacy models use the Garmin Mode interface and will not mount as a drive when connected to a computer. For memory card information on Garmin legacy models, see - Maximum Memory Card Size for Garmin Legacy Models.
