Changing the Battery in the Pro Dog Collar Device
Depending upon several external factors, the battery in the Garmin dog training collars may need to be changed after several years of use.
  • The following is a link to purchase the battery kit with torx screwdriver for the Pro model Dog Devices:
  • For instructions and a diagram on how to change the battery: Battery Change Instructions
    • Caution:
      • When changing the battery, verify the gasket is not damaged
      • When re-closing the case, verify the gasket stays seated in groove
      • Once the case is screwed down, verify the gasket is not sticking out of the device
  • This battery is used in the Pro 70, Sport® Pro, Pro 550 & Pro Trashbreaker™ dog training systems that use the PT 5, PT 6, PT 10, and TB10 dog devices
Related
