How to Configure SRAM AXS Shifting on Edge Cycling Computers
Compatible Edge® cycling computers feature the ability to be controlled by the following components:
SRAM RED AXS
SRAM Force AXS
SRAM Rival AXS
Wireless Blips and MultiClics.
To pair the shifting system to your Edge cycling computer, refer to your owner's manual and search for "Shifting".
NOTE: Ensure your SRAM components have the latest software installed.
Compatible Cycling Computers:
Edge® 540 | Edge® 540 Solar
Edge® 840 | Edge® 840 Solar
Edge® 1040 | Edge® 1040 Solar
- Edge® 1050
Configure SRAM Buttons
First, assign ANT+ Functions in The SRAM AXS App:
Install the SRAM AXS App on your compatible smartphone.
Add your AXS components to the SRAM AXS App.
Select Configure Controls.
Select a component.
Select ANT+ Control.
Assign an ANT + Function of your choice to the component.
While the SRAM AXS system is paired and connected to the Edge:
Access the Edge's list of Sensors.
Select the SRAM AXS Shifting system.
Select Sensor Details.
Select ANT+ Function Setup.
Select Action Type.
AXS MicroAdjust Screen
When you make a change to the MicroAdjust in the SRAM AXS App or using the AXS buttons while paired to a compatible Edge, the Edge will show a screen similar to the one below. The middle number will update as you make adjustments.
