Rally : Replacing the Batteries
WARNING
See the Important Safety and Product Information guide in the product box for product warnings and other important information.
Each Rally™ 200 pedal uses one CR1/3N battery.
NOTE: Garmin® recommends replacing all of the batteries at the same time. Do not mix the battery types.
  1. Use a 4 mm hex key to remove the battery cover Callout number one.
    Device with a hex key and a glyph
  2. Remove the battery.
  3. Wait 5 to 10 seconds.
  4. Insert the new battery into the battery cover, observing polarity.
    Battery and the battery cover
  5. Replace the battery cover, and hand tighten it.
    NOTE: Do not damage or lose the O-ring gasket.
  6. Use a 4 mm hex key to tighten the battery cover to 3.6 lbf-ft. (5 N-m).
    The LED displays one short green flash followed by one long red flash.
