The T5, T5 mini, and T5X dog collars will display different light sequences to let you know the status of the collar while in use or during charging. The different colors and flashes are described in the tables below.
Light Sequences When In Use:
Single green blink | Acquiring satellite reception |
Double green blink | Acquired satellite reception |
Triple green blink* | Acquired strong satellite reception |
Rapid green flash | Waiting to pair (T and TT collars only) |
Solid green | Producing stimulation (TT collars only) |
Solid red | Waiting for button release (TT collars only) |
Light Sequences When Charging:
Solid red | Currently charging |
Solid green | Fully charged |
Flashing red | Charge fault (issue with charging the battery) |
Light Sequences When Updating Software:
Solid yellow | Erasing code, loading code to computer |
Flashing yellow | System code missing |
Solid red | Waiting for a button release to turn off |
Light Sequences In Sleep Mode:
Available for the TT 15x/ T5x and TT 15 mini/T5 mini collars only.
Rapid Green, followed by rapid red | Unable to put into sleep mode. |
Single red blink | Sleep mode |
*Waiting for the triple blink is not required but will provide the best accuracy.
