Europe Map Regions
null
Current Map Version: 2026.20 (Europe) as of May 28, 2025.
Effective with the 2025.20 map release, devices purchased with a map subscription for a specific Europe map region have been upgraded to the full Europe map at no additional charge. These regions are no longer available to download as a smaller subset, with the exception of the regions shown below.
Also effective with the 2025.20 map release is the addition of coverage for Armenia, Azerbaijan, and Georgia.
During a map update, Garmin Express™ software may prompt you to use a memory card when there is not enough internal storage to install full coverage. We recommend that you use a compatible SD card to install the update.
When purchasing or receiving a map update, unless otherwise stated, the updates you receive under the subscription will update the same geographic area included with your Garmin product when originally purchased. In that case, some of the regions below may not be available since they include states, provinces, and/or areas that were not originally pre-loaded to your device. To see what mapping was preloaded on your device, go to the Support Center, and enter your Product Name or Serial Number. Once your device is selected, in the Search for a solution... box, type or copy in "What Maps are Preloaded on my Automotive Device?"
You can purchase maps for other countries for your compatible automotive device by visiting Garmin's Online Store.
Devices loaded with Europe full coverage will have the map displayed as two separate entries:
- CN Europe NTU ALL North
- CN Europe NTU ALL South
Other items that deliver features to your GPS navigator are included with either of the above files. Therefore, if you update Europe full coverage mapping, both files must be present and enabled with a checkmark on your GPS navigator for it to have full functionality.
For steps to verify the maps installed on the device, go to the Support Center, and enter your Product Name or Serial Number. Once your device is selected, in the Search for a solution... box, type in Verify Maps, then select the corresponding FAQ.
Click an Image or Map Name to See the Map in Full-Screen Mode.
Full Coverage of Europe | Southern Europe | UK & Ireland |
The coverage listed is not intended to be exhaustive. Refer to the map image for additional information.
