Editing Data Screens on the MARQ Series
The activity data screens on the MARQ series can be edited, reordered, or removed. This allows for customization of the data you see while in an activity, only seeing the data that is most important to you.
Note: The steps below were introduced to the MARQ series in software version 6.00. Update the software of your MARQ series watch to follow these steps. For steps on updating, see - How to Install Software Updates to My MARQ Series Watch
Opening the Edit Menu
These steps guide you to the menu where edits can be made to your data screens and data fields.
- Press Start/Stop to enter the activity list
- Select an Activity
- Press and hold Menu to open settings
- Select Activity Settings
- Select Data Screens
- Select the screen you wish to edit
You can now make changes to data screens and data fields.
Choose the option below that matches the changes you would to make and continue with the steps.
Editing a Data Screen Layout
- Select Layout
- Select a new layout for the data screen
Note: Press Back twice to exit the menu.
Editing Data Fields
- Select Data Fields
- Select a field to edit
- Select a category of data fields
- Select a data field
Reordering a Data Screen
- Select Reorder
- Press Up or Down to reorder the data screen
- Press Start/Stop to confirm the placement
Removing a Data Screen
- Select Remove
- Select Yes to remove
Adding a Data Screen
- Select Add New
- Select the type of data for the screen to display
- Press Up or Down to reorder the new screen
- Press Start/Stop to confirm the position
Edits can now be made to the new data screen.
