Customizing the Watch Face on a fēnix E Watch
fēnix® E watches offer the ability to customize what data is displayed on the watch face. The selected watch face may change what can be customized, what options are available, or how the data appears. The instructions below are for customizing the pre-loaded watch faces. For instructions on customizing watch faces that have been downloaded from the Connect IQ™ Store, see - How to Customize a Watch Face Through Connect IQ Store. The video below will walk you through the steps to customize your watch face.
The fēnix E watch allows you to save your customizations to different watch faces. You can have up to ten saved watch faces, and you can use the same template to create multiple versions of the same watch face.
  1. From the watch face, hold UP/MENU (middle left) button.
  2. Select Watch Face.
  3. Press UP/MENU (middle left) button or DOWN (lower left) button to scroll through your saved watch faces.
  4. Scroll to a saved watch face or select Add New to add a new saved watch face.
  5. Press START (upper right) button on the face you want to customize, then select an option.
    NOTE: Not all watch faces will have all of the following options.
    • Select Styles to change the style of the background which may include shading, color, or in some cases whether the face is digital or analog.
    • Select Data to change what data options appear.
      1. The field that is being customized will pulse and what is currently shown there will be listed at the bottom of the screen.
      2. Press START (upper right) button to customize the pulsing field or scroll to a different field.
      3. Scroll to see the available data options, the name of the data will show at the bottom of the screen.
      4. Press START (upper right) button to save the changes and move on to the next data field.
      5. Select Done after all fields have been customized.
    • Select Accent Color to change the color that is adjustable on the watch face.
    • Select Data Color to change the color of the data that appears on the watch face.
    • Select Alt. Time Zones to add or edit an alternate time zone. Alternate time zones point to the time based on a 24 hour dial, and the watch face will only show one alternate time zone at a time.
  6. Select Apply to save changes and use the current watch face.
If you are uncertain what a symbol on your watch face means, you can touch and hold on the field to be taken to the associated widget glance, or you can follow the steps above to customize the data on the watch face. When the data field you want to know more about is pulsing, it will list what the field is showing at the bottom of the screen.
Available Watch Face Templates
The watch face templates shown below can be customized using the steps above.
Watch Faces Templates Available on fēnix E Watches
Digital Watch Face With 3 Gauge Data Fields on Top and both Sides and 1 Circular Data field at the BottomPropulsion
Digital Watch Face With 2 Gauge Data Fields on either Side and 2 Text Data Fields on Top and Bottom
Radial Precision
Adjusting the Styles of this watch face switches between an analog or digital time option.
Digital Watch Face With 2 Gauge Data Fields on either Side, 1 Text Data Field at the Top, and 2 Text Data Fields at the BottomBold Stack
Analog watch face with subtle background of contour lines includes 2 gauge data field on the right and left and 3 text data fields
Contours
Requires Software Version 12.22 or newer.
Digital watch face with 2 arc gauge data fields and 1 text data field on the right and 3 circular data fields on the left
Industrial
Requires Software Version 11.89 or newer.
Digital watch face with data fields around the outside edge
Portal
Watch Face Data Customization Options
Depending on the watch face you have selected, the data options may vary. Some watch faces may also include larger graphical data fields for things like VO2 max, Training Status, or solar charging information.
For more information on available data field options, see  What Do the Watch Face Icons on My Garmin Watch Mean?
Deleting a Saved Watch Face
You can have up to ten saved customized watch faces. After you have saved 10 watch faces, if you want to create a new watch face, you will need to delete one of your saved customizations in order to add a new  customized watch face. Deleting a saved watch face does not delete the watch face template from your watch.
  4. Press START (upper right) to select the face that you want to delete.
  5. Select Delete.
Related
