Replacing the Battery on a Garmin Approach CT10
There are times the Garmin Approach® CT10 golf sensor battery needs to be replaced. See the guidelines below demonstrating how to replace the battery.
Changing the Battery of the Approach CT10 Golf Sensor
For this process, it is recommended to leave the sensor attached to the golf club. It may require a high amount of torque to remove the battery cap and we recommend using the Battery Cap Tool.
  1. With one hand, firmly grip the white mount of the sensor.
  2. With the other hand insert the cap removal tool, twist the black sensor cap counter-clockwise until it can be removed.
    Remove Cap With Removal Tool
  3. Remove the battery from the black sensor cap.
  4. Replace the battery with a new CR2032 battery.
    NOTE: Ensure the + icon is face up and pointing away from the sensor cap.
    battery removal
  5. Place black sensor cap back on the white mount and twist with the tool clockwise until it locks.
    Placing Cap Back on With Tool
Checking the Approach CT10 Battery Level
While your device will notify you when the battery is low or critical, the battery life can be checked at anytime. Select your device below and follow the steps outlined.
NOTE: The sensor must be actively paired to view battery life.
Approach G12 and S12 Devices
  1. From the time of day, press OK.
  2. Select Golf Settings.
  3. Select Club Sensors.
  4. Select desired connect club sensor.
  5. Select About.
On the About screen, one of the fields will display: Battery and provide the current level as New, Good, OK, Low, or Critical.
Approach G20 Solar Golf Handheld
  1. With the Approach G20 Solar golf handheld powered on, select Settings.
  4. Select desired club sensor.
  5. Select About.
Approach S20 Watch
  1. With the Approach S20 watch powered on, Press OK.
  2. Select Settings.
  3. Select Club Tracking.
  4. Select Club Sensors.
  5. Select Paired Sensors.
  6. Select desired connect club sensor.
  7. Select About.
Approach S40 and S42 Watches
  1. With the Approach S40 watch powered on, Press and hold the button to get to the Main menu.
  2. Touch Golf Settings.
  3. Scroll down and tap Club Sensors.
  4. Touch on desired club.
  5. Touch on About.
Approach S44 and Approach S50 Watches
  1. With the Approach S44 or S50 watch powered on, Press and hold the top button
  2. Tap Settings.
  3. Tap Golf Settings.
  4. Tap Club Tracking.
  5. Tap Club Sensors.
  6. Tap desired connected club sensor.
  7. Tap About.
Approach S60 and Approach S62 Watches
  1. With the Approach S60 or S62 watch powered on, Press Menu Icon.
  2. Tap Settings.
  3. Tap Sensors & Accessories.
  4. Tap Club Sensors.
  5. Tap Paired Sensors.
  7. Tap About.
Approach S70 Watch
  1. With the Approach S70 watch powered on, Press Menu Icon.
  2. Tap Settings.
  5. Tap desired connected club sensor.
  6. Tap About.
For more information on the Approach CT10, see the owner's manual.
