Pairing a Dog Tracking Collar to the Astro 430
Up to 20 compatible dog tracking collars can be paired to the Astro® 430 dog tracking handheld wirelessly using MURS/VHF, by entering the track and control codes, or by sharing wirelessly from another handheld using ANT+ technology. Up to 20 collars can be actively tracked at one time.
Adding a Dog Collar Wirelessly using MURS/VHF
To pair wirelessly, the collar should be within close proximity (approx. 10 feet) to the handheld and away from sources of interference.
Ensure the removable antenna is installed on the Astro 430 handheld.
Power on the Astro 430 handheld.
Put the dog collar in pairing mode. For steps, choose your collar model below. null
Press the Dog button.
Select Add Dog.
Select Yes.
Use the keyboard to enter a dog name.
Select Ok. NOTE: If you have other collars to add, select Add More.
Dog collars can be paired to an Astro 430 handheld using track and control codes if the collar has already been paired to a different handheld. Track codes allow the Alpha® 200 or Alpha® 200i handheld to track the collar; Control codes allow the handheld to both track and use training functions of the collar.
Select Add Dog.
Select No.
Select Yes.
Enter the track or control code for the collar. NOTE: For steps to find the share code for the collar, reference "Locating Track and Control Codes" below.
Enter the Dogs name.
Select OK.
Alpha® XL Navigator
Select Pro View
Select a dog
The Track and Control codes are displayed below the dog's name.
