Pairing a VIRB X, XE and ULTRA 30 Camera to a GPSMAP 74xx, 76xx, or 8xxx Series Chartplotter
The VIRB X or XE Action Cameras can connect to Garmin GPSMAP 74xx, 76xx, and 8xxx series chartplotters via Wi-Fi1. To pair the VIRB to a compatible chartplotter, please do the following on the VIRB:
  1. Press and Hold Menu until the Main Menu appears
  2. Scroll (using the Up Arrow/Menu and Down Arrow/Power buttons) to Wi-Fi
  3. Press OK
  4. Scroll to Mode
  5. Press OK
  6. Scroll to Join
  7. Press OK
  8. Scroll to the appropriate chartplotter Wi-Fi network
  9. Press OK
    • If this is the first time connecting (or the password is incorrect), after a few moments a message stating “Connection Failed. Enter Password?” will appear
  10. Scroll to Yes
  11. Press OK
  12. Enter the network password
    • Use the Up and Down buttons to scroll and press OK to move to the next character
    • Once finished, scroll to the check-mark and press OK
  13. A message stating you are connected to your network should appear
  14. Press OK
  15. Press the VIRB button listed under the AV, Gauges, Controls button on the chartplotter
The VIRB ULTRA 30 Action Cameras can connect to Garmin GPSMAP 74xx, 76xx, and 8xxx series chartplotters via Wi-Fi1. To pair the VIRB to a compatible chartplotter, please do the following on the VIRB:
  1. Select Settings
  2. Select Wireless
  3. Select Mode
  4. Select Connect
  5. Select the appropriate chartplotter Wi-Fi network
  6. Select Yes
  7. Enter the Password
  8. A message stating you are connected to your network should appear
  9. Select OK
  10. Press the VIRB button listed under the AV, Gauges, Controls button on the chartplotter
1Please consult the Owner's Manual for your chartplotter to setup its Wi-Fi network.
Note that these chartplotters can pair up to a maximum of five VIRB devices.  Only four of them can be view-able on a single screen at one time.
Further operational information for the VIRB camera can be found in the Owner's Manuals for each device.
