You are viewing an article that is not available in your currently selected language. You can choose another one below.
Garmin HUD/HUD+ Reset
The Garmin HUD/HUD+ has a reset feature that can be used if the device appears to be frozen or if there is a problem with the Bluetooth connection.
To reset the Garmin HUD/HUD+:
- Press and release the reset button (located on the backside, just under the device)
- The Garmin HUD/HUD+ will display Pair
- After about 10-30 seconds the Garmin HUD will resume navigation again
The app will continue to navigate as normal while the Garmin HUD/HUD+ resets.
