Items That Sync Through Earthmate
Earthmate® mobile app acts as an extension of your inReach® satellite communication device. The app allows you to mark waypoints, type messages, and access a larger screen for viewing maps. Earthmate will also receive information from your Garmin Explore™ account, and send data to your inReach device when it is synced.
IMPORTANT
- To sync Garmin Explore website changes, a cellular data or Wi-Fi connection on the paired mobile device is required and the compatible inReach device must be powered on and connected.
- Always check your inReach device after performing a sync to be sure that the data you would like on the device is present.
- On a suspended account, data recorded by an inReach device will not sync to Earthmate app or the Garmin Explore website. Data recorded during this period will sync once the account has an active subscription.
- For Professional accounts, profile changes cannot be synced using Earthmate app. For more information, see Using Profiles as an inReach Professional Administrator.
NOTE: If the Earthmate app has been deleted or installed on a new mobile device, messages older than one year may not sync to a newly installed Earthmate app.
Items That Sync to an inReach Account From Earthmate App
- Tracks
- Waypoints
Items That Sync From an inReach Account to Earthmate App
- Contacts
- Check-In Messages (formerly known as Preset Messages)
- Quick Text messages
- Routes
- Recorded Tracks (inReach SE must have SEND interval turned on)
- Waypoints
Syncs between Earthmate app and inReach devices will automatically occur while the two are paired and connected. For more information, see - Syncing inReach Account Changes With the Earthmate App.
NOTE: If you receive errors, have issues with sending or receiving messages, or do not see your data on the Garmin Explore website after syncing with Earthmate, use the inReach Sync program on a computer to sync your inReach device. For more information, see - Items That Sync Through the inReach Sync Program to an inReach Device.
