(2024) Service Bulletin 24078 Rev B: Approval of GTX™ 3X5(R) Transponder Main Software Version 2.85 and ADS-B Software Version 3.51
PRODUCTS AFFECTED:
GTX 3X5(R) units installed using GTX 3XX Part 27 ADS-B AML STC SR02124SE are affected.
CERTIFICATION AUTHORIZATION:
SR02124SE MDL Revision 6
COMPLIANCE:
Recommended: Compliance with Service Bulletin 24078 is recommended at the next scheduled maintenance interval
PURPOSE:
This STC Service Bulletin provides notification of an update to STC SR02124SE, GTX 3X5(R) with ADS-B AML STC, MDL Revision 6.
GTX 3X5 Main Software Version 2.85:
- Improved display handling of the alert message dialog subpage
- Improved the robustness of non-volatile memory data
CAUTION
Not upgrading software may result in the unit being returned to the factory due to a loss of calibration data.
GTX 3X5 ADS-B Software Version 3.51:
- Improved the ADS-B SURF application status reporting
- Addressed a timing issue that could result in TAS/TCAS-only targets being temporarily removed from the traffic display intermittently
- Corrected an issue where daily NOTAM TFRs were only displayed on the first day that they were published. Daily NOTAM TFRs are now displayed until they are no longer active.
- Updated aural alert processing to use relative bearing for TAS/TCAS targets. This now matches functionality for ADS-B targets and improves directional callout accuracy for rotorcraft.
WARRANTY INFORMATION:
This modification is warranty reimbursable with a deadline of December 31, 2025.
