Important Notice: Beware of Fake Garmin Ads!
Garmin Philippines has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Access Navionics Charts and Features on Marcum MX-7GPS Plotters
Plotter Software
IMPORTANT: Plotter manufacturer’s latest software updates required.
Check your plotter’s software by pressing the MENU button and select SYSTEM SETTINGS. Version will be listed in the lower-right corner.
Current chart plotter/sounder software update versions
NOTE: Do not use your Navionics® card to update your plotter software or have it in your plotter when you update.
Chart Layers
SonarChart™ OFF = Nautical Chart – official charting detail
SonarChart ON = SonarChart – high-definition bottom contour detail
Go to Menu > GPS Map > Settings > SonarChart
Navionics Recommended Chart Settings
Go to Menu > GPS Map > Settings to access:
Details (All)
Depth Contours (All)
Optional Chart Settings/Features
2D Shading (On/Off) – Gives maps a textured view
Dynamic Icons (On/Off) - Tides/Currents
Easy View (On/Off) - Text and icon magnifying feature
[Navionics] Community Edits (On/Off)
Features Available With Navionics Platinum+™ Products
Satellite Imagery, Relief Shading or Sonar Imagery
Menu > GPS Map > Settings > Layers = Land and Sea
Transparency: 0 = Full Overlay (harder to see chart details) or 100 = Less Overlay (harder to see overlay details)
Panoramic Photos
Target a camera icon using your cursor and select the pop-up to display detailed information.
3D Views
Menu > GPS Map > Settings > 2D/3D
Allows for a three-dimensional view of water contours with the ability to pan and rotate the chart information at different angles.
Navionics Advanced Features
Advanced Features are included with an active subscription for updates on your chart plotter card. Not all features are available for all models. See our Compatibility Guide for the most current information.
Advanced Map Options
Menu > GPS Map > Advanced
SonarChart Density – density of contours displayed on SonarChart layer
Fishing Range – select a range of depths to fill with a different color
Shallow Water – highlights shallow water between 0 and up to 10m/30ft
SonarChart Live
  1. Go to Menu > GPS Map > Settings
  2. SonarChart (On); Depth Contours (ALL)
  3. Go to Menu > GPS Map > Advanced
  4. Select Sonar Log > Record
Transparency – 0 = Full Overlay (harder to see chart details) or 100 = Less Overlay (harder to see overlay details)
Minimum Depth – All contour lines up to that depth will display
SonarChart Live Tide Correction – Allows contours to be adjusted according to nearest tide station (coastal marine waters)
