Performing a Master Reset on the Xero S1 Trapshooting Trainer
If the Xero® S1 trapshooting trainer is having difficulties powering off or appears to be frozen for some reason, then a Master Reset of the device may be needed to re-establish functionality.
A Master Reset of the Xero S1 trainer will delete all profile and scoring data currently on the device and set all menus back to the default settings. This process should only be done after all other means of troubleshooting have been attempted.
Master Reset for the Xero S1 Trapshooting Trainer
  1. Turn the Xero S1 trainer OFF.
  2. Press and Hold Power button in.
  3. The status light will flash green for one second, then yellow in lower right of the device.
  4. Continue to hold Power, but then tap the middle of touchscreen 5 times.
  5. Release Power button.
  6. Select Language and follow the reset of the setup options as prompted.
Related
