Adjusting the Temperature Reading from a Garmin Transducer or Intelliducer
The Temp Offset feature allows users to adjust the water temperature readings from a connected Garmin transducer or Intelliducer, if needed. Below are instructions to create a temperature offset.
ECHOMAP™ chartplotters & STRIKER™ fishfinders
From the main page select Settings > My Vessel > Temp Offset enter preferred offset. Select Done to save settings.
NMEA 2000 intelliducer connected to ECHOMAP Series
From main page Settings > Communications > NMEA 2000 Setup > Device List > highlight transducer > Review > set to desired offset > Done to save settings.
Current GPSMAP® chartplotters1
From any page select Options > Settings > My Vessel > Temp. Offset change to preferred offset. Select Done to save settings.
NMEA 2000 Intelliducer connected to Current GPSMAP Series
From any page select Options > Settings > Communications > NMEA 2000 Setup > Device List, highlight the transducer, select Review > Temp, Offset
1 Legacy GPSMAP units have a different menu structure see Owner's Manual for steps. Finding the Owner's Manual for a Garmin Device explains how to locate the owner's manual.
