Calibrating the Edge 800 Touchscreen
The Edge 800 touchscreen allows you to directly interact with items shown on the screen. If the touch-response is delayed or activating the wrong items, the touchscreen may need to be calibrated. Calibrating the screen will allow the Edge 800 to fine tune the input it receives from you.
Calibrate the Edge 800 Touchscreen:
Select Menu.
Select the Wrench.
Select System.
Select Display.
Select Screen Calibration.
Continuously press the dot until a "Calibration is Complete" message appears.
Select OK.
The touchscreen on your Edge 800 should not be calibrated and ready to use.
Manual Calibration
This should only be performed if the touchscreen is completely inoperable and the steps above cannot be performed.
Power off the Edge 800.
Press and hold the LAP/RESET key.
While still holding the LAP/RESET key, Power on the Edge 800.
Release LAP/RESET when "Touch the Dot" appears.
Follow onscreen instructions to complete calibration.
