How to do a Factory Reset on the Xero X1i Crossbow Scope
Resetting the Xero® X1i crossbow scope may be necessary for the following:
- Moving the sight from one crossbow to another.
- A mistake is made during the setup process.
- Calibrating broadheads that differ from field tips.
- Making adjustments to the crossbow (new strings, new cams, etc.)
Performing a Factory Reset in the System Menu
- Access the Main Menu by pressing the OK / PWR button.
- Scroll to
> SYSTEM.
- Select RESET ALL SETTINGS.
- Follow the onscreen instructions to finish the Factory Reset.
NOTE: Successfully completing this process will take you back to the Language Selection screen.
