General Guidelines for Creating Garmin Custom Maps
Certain guidelines need to be followed when creating Garmin Custom Maps to ensure they work correctly on your device.
Note: Outside of providing guidelines and requirements for Garmin Custom Maps, we cannot assist with or support these maps as they are user-created and considered third-party.
Guidelines for Creating Custom Maps
  • More than one jpeg can be in a KMZ file.
  • The only kml file that will be processed is a doc.kml, inside the KMZ file.
  • JPEG files are the only supported image type.
  • JPEG files must be saved without Progressive Image (typically found under advanced options).
  • KMZ files are read from \Garmin\CustomMaps directory on both the device's internal memory and on the SD Card.
    • Garmin BaseCamp™ software will display custom maps; however, custom maps cannot be sent from Garmin BaseCamp™ to a product that supports custom maps. Custom maps must be manually placed in the CustomMaps folder of the device they are to be used on.
    • Overlander® navigator users: The CustomMaps folder needs to be created and added to the first Garmin folder on the device.
  • Images over 1 megapixel (1024x1024 pixels, 512x2048 pixels, etc.) will be rendered at a reduced resolution on the device. If this is causing a problem for your map, you can split the image and use multiple JPEG files inside of one KMZ file.
  • Each JPEG should be less than 3MB.
  • The max number of Custom Map JPEG images that can be loaded:
    • Typically 100 for supported devices.
    • Exceptions to this are the: Montana® series (500), Monterra™ (99), Oregon® 600/700 series (500), GPSMAP® 64/65/66 series (500) outdoor handhelds.
  • The size of the JPEG files will affect the draw speed on the Garmin device.
  • There is no limitation on KMZ file size as long as the previous limitations are met.
  • Since each KMZ file will need at least one JPEG file to be a functional custom map, KMZ file limitations match JPEG limitations.
  • Custom Maps are enabled or disabled individually or as a group, depending on the Garmin device model.
    Compatible Devices That Enable or Disable Custom Maps Individually
    • Dog Tracking Handhelds
      • Alpha® 200 & Alpha® 200i
      • Alpha® 300 & Alpha® 300i
    • Outdoor Handhelds
      • eTrex® Touch 25 | eTrex® Touch 35 | eTrex® Touch 35t
      • GPSMAP® 276Cx
      • GPSMAP® 64s | GPSMAP® 64sc | GPSMAP® 64st | GPSMAP® 64sx | GPSMAP® 64csx
      • GPSMAP® 65 |  GPSMAP® 65s
      • GPSMAP® 66i | GPSMAP® 66s | GPSMAP® 66sr | GPSMAP® 66st
      • GPSMAP® 67 | GPSMAP® 67i
      • GPSMAP® 86i | GPSMAP® 86s | GPSMAP® 86sc | GPSMAP® 86sci
      • Montana® 700 | Montana® 700i | Montana® 710 | Montana® 710| Montana® 750i | Montana® 760i
      • Monterra®
      • Oregon® Series
      • Rino® 750 | Rino® 750t | Rino® 755t
    Compatible Devices That Enable or Disable Custom Maps as a Group
    • Dog Tracking Devices
      • Alpha® 501
      • Alpha® 100
      • Astro® 320
      • Astro® 430
      • Astro® 900
      • Atemos 501
      • Atemos 1001
    • GPS Navigators
      • Arctic Cat G8 Display
      • BMW Motorrad Nav V
      • BMW Motorrad Nav VI
      • Can-Am Spyder zūmo® 590
      • Ducati zūmo® 395
      • Harley Davidson Roadtech zūmo® 590
      • Kawasaki RIDGE 8" Tread Display
      • Overlander®
      • Tread®
      • Tread® - Base Edition
      • Tread® 2 Series
      • Tread® - Overland Edition
      • Tread® XL - Overland Edition
      • Tread® - SxS Edition
      • Tread® XL - Baja Chase Edition
      • Tread® XL - Baja Race Edition
      • zūmo® 395
      • zūmo® 396
      • zūmo® 590
      • zūmo® 595
      • zūmo® XT
      • zūmo® XT2
    • Outdoor Handhelds
      • Colorado® Series
      • Dakota™ Series
      •  eTrex® 20 | eTrex® 20x | eTrex® 22x | eTrex® 30 | eTrex® 30x | eTrex® 32x
      • GPSMAP® 62 | GPSMAP® 62s | GPSMAP® 62sc | GPSMAP® 62st | GPSMAP® 62stc
      • GPSMAP® 78 | GPSMAP® 78s | GPSMAP® 78sc
      • GPSMAP® 79s | GPSMAP® 79sc
      • Montana® 600 Series
      • Rino® 600 Series
    1These devices are sold and designed for use in Europe only.
Related
