External Multi-Switch Button Doesn't Work
If an external multi-switch button is not working:
- Check that the correct resistors are attached
- 68 ohm for a multi-switch
- 120 ohm for a dual fixed multi-switch
- Check that the resistors are properly attached and working
- Check that the LED turns green on the input channel when the button is pressed
Note: only pulse breakers will work with a multi-switch input channel
