LIDAR-Lite v3/v3HP Beam Specifications
At very close distances, less than 1 meter, the LIDAR-Lite v3/v3HP beam diameter is roughly the size of the transmit lens. For distances greater than 1m the beam diameter can be estimated using the following equation:
Distance/100
This will estimate the spot size in whatever units were used to measure the distance. The beam spread specification is ~8 milliradians or ~0.5 degrees. It should also be noted that the beam is not a circular spot, but instead is more of an oval due to the laser being a rectangular, edge emitting source.
Laser specifications related to wavelength, mode, pulse width, etc., may be found in the owners manual.
For more information on your specific device, please see the owner's manual. To find the owner's manual, visit the Garmin Support Center, identify the specific device you are using, and select manuals on the left of the page. See the Related Content below.
