Entering and Exiting Sleep Mode or Rescue Mode on the Alpha 200 Plus or Alpha 300 Series
Sleep Mode
When using an Alpha® 200 Plus, Alpha® 300, or Alpha® 300i dog tracking handheld with compatible collars, you will be able to put the collar in Sleep Mode. Sleep Mode can be used to conserve the battery when you are not actively tracking your dog. Sleep Mode can be used at a distance, as long as the handheld and collar are fully able to communicate.
  1. Select Dog List
  2. Select the dog who's collar you want to put in Sleep Mode
  3. Select ALpha 300 Menu
  4. Select Adjust Collar Sleep Mode
  5. Select Sleep or Wake
NOTE: For the Alpha T20 and Alpha TT25 collars the LED light on the collar will being to flash purple every 10 seconds indicating that the collar is asleep. For all other GPS collars the LED light will not flash.
Rescue Mode/Battery Saver Mode
Rescue Mode extends the battery life of the dog tracking collar to allow for more time to locate the dog. Enabling Rescue Mode changes the collar settings so when the collar reaches 25% battery life the update rate for the collar automatically changes to 2 minutes. To turn on this mode the dog collar must be within 10 feet (3 meters) of the handheld. You can not enable rescue mode at a distance.
  1. Select Dog List
  2. Select the dog you want to put in Rescue Mode
  4. Select Rescue Mode
  5. Select Enable or Disable
You can also enable or disable Rescue Mode from the dog's information page by tapping the screen where it says  Rescue Mode, from here it will give you the option to Enable or Disable.
Collars Compatible With Sleep Mode
  • Alpha T20
  • Alpha TT25
  • T 5 Mini
  • T 5X
  • TT™ 15 Mini
  • TT™ 15x
Collars Compatible With Rescue Mode
  • Alpha T20
  • Alpha TT25
  • T 5
  • T 5 Mini
  • T 5x
  • TT™ 15
  • TT™ 15 Mini
  • TT™ 15x
