ECG App Results Are Not Showing Up in Garmin Connect
Check the following items to ensure that your Garmin Connect™ account settings are enabled to upload and display ECG app recordings.
Upload Consent
You must enable activity upload and Data Storage & Processing for ECG app results to sync to your account. To enable these settings:
Open the Garmin Connect app.
Access the menu by selecting More (bottom right).
Select Settings.
Select Profile & Privacy.
Select Data.
Select Device Upload and then select the toggle switch to enable.
- Select Storage & Process and Agree.
If you revoke consent at any time, all previously uploaded ECG recordings will be deleted from Garmin Connect.
Enable Two-Step Verification
You must enable two-step verification for your Garmin Connect account. To do so, go to Garmin.com/account, log in with your username and password, choose “Update sign-on settings,” and follow the instructions to enable two-step verification.
