Important Notice: Beware of Fake Garmin Ads!
Garmin Philippines has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Customizing Data Fields on GPSMAP Series Handhelds
Data fields on the Map, Compass, Trip Computer, and Altimeter/Elevation Plot pages can be customized to show different data on GPSMAP® series outdoor handhelds.
Changing Data Fields on GPSMAP 62, 64, 65, 66, and 67 Series Handhelds
For steps to customize individual data fields or add a dashboard with data fields to the Map page, choose your model series below.
GPSMAP 62 Series Handhelds
For a list and description of available data fields on the GPSMAP 62, 62s, 62st, 62sc, and 62stc, view page 25 of the owner's manual.
Customizing Data Fields on the Compass, Trip Computer, or Altimeter/Elevation Plot Page
  1. Open the page for which you will change the data fields.
  2. Press MENU.
  3. Select Change Data Fields.
  4. Select a data field to change.
  5. Choose an option.
  6. Press QUIT when you are finished.
Customizing Data Fields on the Map Page
  1. While viewing the Map page, press MENU.
  2. Select Setup Map.
  3. Select Data Fields, then select an option:
    • 1 large.
    • 2 small.
    • 4 small.
    • Dashboard: Allows you to choose from a list of themed dashboards with preselected data. The data displayed in these dashboards cannot be customized.
    • Custom: Allows you to choose different data field layouts for When Navigating and When Not Navigating.
  4. Press QUIT to return to the Map page.
  5. Press MENU.
  6. Select Change Data Fields.
  7. Select a data field to change.
  8. Choose an option.
  9. Repeat steps 7 and 8 for any additional fields you wish to change.
  10. Press QUIT when you are finished.
GPSMAP 64 and 65 Series Handhelds
For a list and description of available data fields on the GPSMAP 64, 64s, 64sc, 64st, 64x, 64sx, and 64csx, view the GPSMAP 64 series / GPSMAP 64x series Owner's Manual.
For a list and description of available data fields on the GPSMAP 65 and 65s, view the GPSMAP 65/65s Owner's Manual.
  2. Press MENU.
    • 1 large.
    • 2 small.
    • 4 small.
  5. Press MENU.
GPSMAP 66 Series Handhelds
For a list and description of available data fields on the GPSMAP 66s, 66st, and 66sr, view the GPSMAP 66 Owner's Manual.
For a list and description of available data fields on the GPSMAP 66i, view the GPSMAP 66i Owner's Manual.
Customizing Data Fields on the Trip Computer Page
  2. Press MENU.
  3. Select an option:
    • Change Data Fields: Select a data field to change, select a data field category, then choose an option from the list.
    • Change Dashboard: This option changes what is displayed in the top quarter of any Trip Computer page. Large Data Field and Small Data Fields are the only dashboards with editable data fields.
    • Insert Page: Inserts an additional page of customizable data fields.
      NOTE: The top four data fields will display the same data on all pages. The remaining data fields of each page can be customized individually.
    • Remove Page: Removes an additional page of customizable data fields.
    • More Data: Adds additional data fields to the trip computer.
    • Less Data: Removes data fields from the trip computer.
  4. Select Change Data Fields.
  5. Select a data field to change.
  6. Select a data field category, then choose an option.
  7. Press QUIT when you are finished.
Customizing Data Fields on the Compass Page
  2. Press MENU.
  4. Press QUIT when you are finished.
Customizing Data Fields on the Altimeter/Elevation Plot Page
  2. Press MENU.
Customizing a Data Field on the Map Page
  2. Select Map Setup.
  3. Select Dashboard,
  4. Select Large Data Field to set a specific data field to display at the top of the map.
    NOTE: Altimeter, Compass, and Geocache dashboards are also available, but these dashboards cannot be customized.
  5. Press QUIT to return to the Map page.
  6. Press MENU.
  7. Select Change Data Fields.
    NOTE: If this option is not available, select Show Dashboard, then press MENU again.
  8. Press ENTER to select the large data field.
  9. Select a data field category, then choose an option.
GPSMAP 67 Series Handhelds
For a list and description of available data fields on the GPSMAP 67, view the GPSMAP 67 Owner's Manual.
For a list and description of available data fields on the GPSMAP 67i, view the GPSMAP 67i Owner's Manual.
  2. Press MENU.
  2. Press MENU.
  2. Press MENU.
  6. Press MENU.
