What Is the LiveTrack Show Course Feature in the Garmin Connect App?
Show Course is a LiveTrack feature in the Garmin Connect app that allows a user to share with others their planned course.  Followers can view the user's real-time location as well as where they will be riding or running.
With the feature enabled, the viewer will see a magenta outline of the course the user will be traveling.  A blue dot will represent the user's current location and as the user completes their activity, a blue line will represent where they have been.
Map of Route
 LiveTrack Course Sharing Example
How Do I Enable This Feature?
Follow the steps below to enable this feature within the Garmin Connect app.
Enabling LiveTrack Show Course
NOTE: The following steps presume that you have previously paired a LiveTrack compatible device to the Garmin Connect app.
  1. From the Garmin Connect app access the Menu:
    • Android: Select Example of three-bar menu icon in the upper left corner.
    • iOS: Select More in the lower right corner.
  2. Select Safety and Tracking.
  3. Select LiveTrack.
  4. Under SUPPORTED DEVICES toggle Show Course on.
LiveTrack Share Course toggle
If the option is not listed to turn this feature on, this means the device that you have does not support this feature.
What Garmin Devices Support LiveTrack Show Course?
This feature is supported by the following devices.  Some may require a software update in order to enable the feature.
  • D2 Mach 1
  • Edge 530
  • Edge 830
  • Edge 1030
  • Edge 1030 Plus
  • epix (Gen 2) series
  • fenix 6 series
  • fenix 7 series
  • Forerunner 245 / 245 Music
  • Forerunner 255 series
  • Forerunner 745
  • Forerunner 945
  • Forerunner 955/955 Solar
  • Instinct 2 series
  • MARQ Collection
  • quatix 6 Series
  • tactix 7 series
  • tactix Delta series
Related
