Rino 600 Series Radio has Muted Volume When Powered On
The volume on the Rino® 600 series handheld can be manually muted by tapping the power button and turning the volume all the way down. This prevents any voice or tones from emitting on the device. If the volume has not been manually muted, but the device still powers on muted, check the tone settings.
Tone Setting
Result
Tones set to Off
The volume will always mute when powered on
Tones set to On
The volume will stay at the manually adjusted level
Utilizing the appropriate volume settings can help insure tone and communications come through when desired.
null
