BarkLimiter and BarkLimiter Deluxe Light Sequences
The BarkLimiter™ and BarkLimiter™ Deluxe bark correction collars will display different light sequences to let you know the status of the collar while in use or during charging (Deluxe only). The different colors and flashes are described in the tables below. Not all bark correction collars will have the below sequencing; this is specific to the BarkLimiter Series Dog Collars.
30 Second Safety Feature
The BarkLimiter collar LED will flash green for the first 30 seconds followed by a quick red flash when powering on or selecting a different training level. No correction can be applied for the first 30 seconds as a safety feature.
Bark Correction
Short red flashMotion detected but no correction applied
Long green flashBark detected and correction applied (vibration or stim as selected)
NOTE: The short red flash can appear amber at times.
Light Sequences When Charging (BarkLimiter Deluxe Collar Only)
Solid redCharging
Solid greenFully Charged
Bark Odometer
When you rotate the dial to N, the LED flashes red and green to report the number of times the device detected a bark since it was last turned on. This can help you track your dog's barking behavior.
Red Flash10 barks
Green Flash1 bark.
Battery Status
To check the battery status rotate the dial, the color of the LED will indicate battery charge level for 5 seconds. After these 5 seconds the collar will start its safety feature and flash for the first 30 seconds followed by a quick red flash.
GreenBattery has good charge
YellowBattery has less than 24hrs left
RedBattery has less than 8hrs left
Related
