Getting Started With the inReach Mini 2
If you are setting up an inReach® Mini 2 satellite communication device for the first time, the following steps will walk you through the process to help you get the most out of your new Garmin product.
Setting up the inReach Mini 2
When powering on the Garmin device for the first time, you will be prompted to configure some settings and activate with an inReach subscription.
- Power on by holding
on top.
Choose your language by scrolling through the list using
and
buttons, press OK to select a language.
Activate your inReach Mini 2 device with an inReach Satellite Subscription.
For more help with activation, see - How to Activate an inReach Mini 2.
Sync and update your inReach Mini 2 with the Garmin Explore™ app and Garmin Express™ software.
For more help with updating and syncing, see - Updating and Syncing an inReach Mini 2.
Learn More About the inReach Mini 2 Handheld
The following articles will help you explore and use the many features of the inReach Mini 2 handheld.
inReach Features
NOTE: Before leaving for a trip, it is recommended to test that you can send out a text message. For instructions, see - Testing Text Messaging on an inReach Handheld.
Activating an inReach Subscription
Messaging
MapShare™ Page & Tracking
SOS
Connected Features
NOTE: Before leaving for a trip, ensure that you are signed into any Garmin apps you will be using and that the inReach shows as connected in the app(s) when it is powered on and within Bluetooth® range.
