How to Install Software Updates to My fēnix Chronos Watch
The software on the fēnix® Chronos watch should be kept up-to-date in order to take advantage of improvements and bug fixes. Updates are free, and easy to install. Software updates can be installed through the Garmin Connect™ app or Garmin Express™ software.
null
Updating the fēnix Chronos Watch Software Through Garmin Express Program
IMPORTANT: If this is your first time using a computer with your watch, you will need to download and install Garmin Express™ software.
  1. Connect your watch to your computer with the USB charging cable.
  2. Launch the Garmin Express program.
  3. Select your watch.
  4. The Garmin Express program will then display the available updates. Select Install or Install All.
    • Review and accept any prompts for Terms and Conditions or Important Notes.
  5. Once complete, disconnect your device from the computer and the watch will ask if you want to "Install Now" or "Install Tonight". If you do not receive this prompt, or if you select "Install Tonight", you can still access the update from the System menu on the watch:
    1. From the main menu on the watch, select or scroll to Settings.
    2. Select System.
    3. Select Software Update.
    4. Select Update Available.
After the watch has installed the update, it will be ready to use.
My Garmin Watch is Not Recognized by Garmin Express Software
If you are having difficulty with this process, search the Support Center with "Garmin Express" identified as the product for further troubleshooting assistance.
