(2006) Service Advisory 0613 Rev A: GDL 69/GDL 69A XM® Satellite Datalink Storm Cell Tracking Limitation
PURPOSE
Garmin has discovered a condition in software version 3.02 or earlier, whereby, tracking greater than 400 storm cells may cause the GDL 69/69A to stop sending data to the host display.
DESCRIPTION
A problem has been identified in the GDL 69/69A which will manifest itself when periods of heavy convective storm cell activity occur. The GDL 69/69A can handle up to 400 storm cells. During periods of unusually heavy activity the total number of storm cells may exceed 400.
If the GDL 69/69A receives a data packet with more than 400 storm cells it will throw away the storm cell data and not pass the data to the display product. The customer may report that they are no longer getting storm cell data or that the age of the storm cell data is getting older.
This is a software limitation that will require a software update to the GDL 69/69A to correct. A GDL 69/69A used in a G1000 installation will stop sending storm cell information when the storm cell count exceeds 400 total for the US. The GDL 69/69A will resume sending data when the storm count drops under the 400 cell maximum. In some cases when the storm count is near the 400 count limit, the GDU 10XX Display may send repeated messages to the GDL 69/69A which will cause the unit to stop sending XM® weather updates. The user may notice that XM® weather products will not be updated. If this occurs, the GDL 69/69A will need to be reset by removing and re-applying power to the GDL 69/69A.
In all cases, the GDL 69A audio products and the on-board radar routed through the GDL 69/69A are not affected and will continue to function.
There is an additional limitation when the GDL 69/69A is being used together with the MX20 Multi-function Display. The MX20 is limited to displaying a total of 255 storm cells. When this number is exceeded, a limitation in the MX20 will cause the unit to enter a safety monitor shutdown mode. Further trouble can be averted by going to the FIS page, selecting the Menu/Enter key and de-selecting “Cell Movement.”
A GDL 69/69A used with a GNS 400 or GNS 500 series product is not affected. The GNS 400
and GNS 500 series does not support the service class that provides cell movement data.
AFMS AND PILOT'S GUIDE CONSIDERATIONS
AFMS and Pilot's Guide procedures for these products are unaffected.
PRODUCT AFFECTED
All GDL 69 and GDL 69A units with software version 3.02 or earlier installed with the MX20 Multi-functional Display or installed as part of a G1000 Integrated Avionics System.
