Description of Wizard Tools
These tools will help you when selecting the right area to download.
- Pan tool
: Allows you to drag the map to pan to a different area of the map. - Zoom tool
: Click on the map or drag a rectangle over the map to zoom into that area. - Box tool
: Drag a rectangle around the desired area you wish to download. - Free-form tool
: Draw a free-form shape around the desired area you wish to download. - Show on Map tool
: Moves the map view to the currently selected area on the map.
Downloading BirdsEye Imagery
- Start the BaseCamp application, and connect the device to your computer.
- Select BirdsEye in the menu bar.
- Select Download BirdsEye Imagery...
- From the drop-down list, select the device with the subscription and select Next.
- From the drop-down list, select your purchased subscription and select Continue.
NOTE: To refine the list, check the box next to Only list products available for my current view. - Use the wizard tools to select the area you wish to download and select Download.
- On this page, you can change the name of the imagery and select a detail level.
- If the download size limit is exceeded, resize the area for download.
- The download will now begin.
- Sending imagery to the Garmin device: Check the box next to Copy imagery to device after download.
- Sending Imagery to an SD Card: To send imagery to an SD card, see - Transferring BirdsEye Imagery to an External Memory Card.
- Select Finish.
The BirdsEye imagery will continue to download in the background. You can continue to use BaseCamp during this time.
