How Does the Auto Sync Feature Work on My vivofit 2?
The vivofit 2 will sync automatically to your smartphone through the Garmin Connect app once you reach 2000 steps within 60 minutes or after an activity is recorded. This count resets after every successful sync, manual or auto.
In addition the following requirements must be met as well:
The device must be in its normal page loop, not on the sleep page.
The device will not sync when using HRM or in an activity.
The device will only sync to connections that have successfully paired in the past.
The vivofit 2 will time out after 8 seconds when trying to auto-sync, or 30 seconds for the manual sync. By default the device will attempt only 8 auto-syncs per day, regardless of success or failure.
