Change the off-route recalculation mode on the zumo 350 and 390
There may be times you want to veer off your route without having the device recalculate the route. To change the route recalculation mode on your device, you must first have the most current version of device software. For step-by-step instructions on how to update the operating system software, please see related content.
To turn off Automatic Route Recalculation once the software is up-to-date:
- Touch Settings
- Touch Navigation
- Touch the option next to Off-Route Recalculation mode1
- Touch the desired recalculation mode
- Touch Save
- Touch and hold the Back button to return to the main menu
1Recalculation modes:
- Automatic will automatically recalculate your route for you if you get off course when following a route
- Off will turn recalculations off. This means that the device will not recalculate the route if you get off course.
- Prompted will have the device prompt you if you would like to recalculate the route when you get off course.
