Removing Maps From an Outdoor Handheld
This article will walk you through removing supplemental mapping from your outdoor handheld.1 Carefully read the important notes below before continuing.
IMPORTANT
Only take the steps outlined in this article if you are confident in determining which files need to be removed from your outdoor handheld.
  • Do not delete gmapprom, gmapbmap, or gmaptz files.
  • Deleting some files in your outdoor handheld can harm your device and make it unusable.
  • Maps downloads expire one year after purchase. If you are deleting downloadable content that is older than one year, you will not be able to download the map again and you will need to repurchase the map.
  • Deleting the wrong map image file from your device may remove preloaded mapping. The preloaded mapping may not be able to be recovered.
When downloading additional maps, it is highly recommended that you download them to a microSD card if your device supports a microSD card. For more information on microSD card requirements, see - List of Outdoor Handheld Interface and MicroSD Card Requirements.
Deleting Mapping
  1. Connect the Garmin device to the computer.
  2. Locate and open the drive for the Garmin device.
    HINT: The drive will be labeled Garmin, or the name of your device.
    • Windows:
      1. Press the Windows key + E on the keyboard to open Windows Explorer/File Explorer.
      2. Select This PC (Windows 10 & 11 only).
      3. Locate the drive for your Garmin and open it.
    • Mac:
      1. Open Finder.
      2. Select Go in the menu bar at the top of the screen.
      3. Select Computer.
      4. Locate the drive for your Garmin and open it.
  3. Open the Garmin folder.
  4. Delete the image (.img) files associated with the map you would like to remove.
    • Examples: gmapsupp.img, D12455025A.img.
  5. Empty the trash on the computer.
  6. Safely eject the Garmin.
    • Windows: Right-click the Safely Remove Hardware icon on the taskbar, then select the device. For more details, see - Safely remove hardware in Windows.
    • Mac: Drag the Garmin device drive on the desktop to the trash.
The map is now removed from your Garmin.
1 For the GPSMAP® 67 series, and Montana® 700 series, see Related for managing preloaded maps.
Related
