NOTE: This feature was made available with software version 3.17. For steps on updating the software, see - Updating the Software on Your inReach Mini 2.
The Map Pick feature allows you to pan the map to a nearby location to select it as a destination, view or edit the details of a saved waypoint, or mark a new waypoint.
From the home page, press
or
to scroll through the widget glances.
Select Navigation.
Press OK to open the options menu.
Select Pan/Zoom Map.
Select an option:
To toggle between panning up and down, panning left and right, or zooming, press OK.
To pan or zoom the map, press
and
Press and hold OK once the desired location is centered on the screen:
Select an option:
If a saved waypoint
was selected:You may be prompted to choose a nearby waypoint from a list if there are multiple waypoints close together.
Select Go to navigate to the point.
Select View Details or View on Map to view details for the waypoint.
Select Edit Details to change the name, icon, or GPS coordinates of the waypoint.
Select Delete to delete the waypoint.
If a new location was selected:
Select Mark Waypoint to save the location as a new waypoint.
