Master reset a Quest
Note: A master reset will erase all waypoints or favorites and will restore your device to the default factory settings.
To perform a master reset on a Quest device, follow these steps:
  1. With the device powered off, press and hold the Page and OK buttons simultaneously
  2. While holding the Page and OK buttons, power the device ON
  3. Release the Page and OK buttons when you see the message, "Would you like to erase all user data"
  4. Select Yes
  5. Press the OK button
The device will power off and back on automatically. You'll be asked to enter your language and time preferences once it powers on again.
After the Quest is set up, place your device in an area with a clear view of the sky until it acquires satellites.
