Testing a transducer without the boat being in the water
You will not be able to test out the transducer's ability to read depth when the boat is not in water. Air dissipates the sound waves produced by the transducer and will cause the transducer to not be able to produce a reading.
The temperature feature of the transducer will work, but it will only be reading the air temperature since it is not in the water.
