Correcting the Wrong Language on a GPSMAP 79 or 86 Series Device
Follow the instructions below if the incorrect language is selected during the GPSMAP 79 or 86 series setup process. See How to Reset the GPSMAP Handheld Devices if a reset is needed.
Changing the Language
  1. Press the MENU key twice to open the main menu
  2. Select Wrench and Screwdriver
  3. Select Gear Wheels
  4. Scroll to and select the second item in the menu
  5. Scroll to and select the desired language
Handhelds With inReach
If a prompt to activate before accessing other settings on the GPSMAP 86i or 86sci  occurs, select the option at the bottom of the screen to skip activation, then proceed with the steps above. Activation can be completed later from the main menu.
inReach Activation Prompt
Related
